Hot enough for ya?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=48132
Author:  meddlingfool [ Sat Aug 13, 2016 1:44 am ]
Post subject:  Hot enough for ya?
New record for me. The 5hp dust collector adds a little spice to the atmosphere. Thinking an air conditioner might be in the cards, but not sure how one could work in a recirculated air scenario...Image
Author:  Don Williams [ Sat Aug 13, 2016 3:09 am ]
Post subject:  Re: Hot enough for ya?
I'm guessing that 33.4 isn't fahrenheit...
Author:  Ken Lewis [ Sat Aug 13, 2016 5:07 am ]
What? Torrified tops?
Author:  printer2 [ Sat Aug 13, 2016 6:35 am ]
That is one way to get the RH down.
Author:  Joe Beaver [ Sat Aug 13, 2016 5:15 pm ]
That is hot. In fact a little hotter than here in Southern California, and they say we are having a heat wave!!!
Author:  meddlingfool [ Sat Aug 13, 2016 5:18 pm ]
It slows a fella down...
Author:  John Lewis [ Sat Aug 13, 2016 6:23 pm ]
Wow, that's about 92*F in the shop. Time to beer down that temperature.
Author:  Alex Kleon [ Sat Aug 13, 2016 6:37 pm ]
My wife just came back from Van, and said the weather was beautiful....but she wasn't in your shop!
Alex
Author:  meddlingfool [ Sat Aug 13, 2016 8:36 pm ]
Oh, it's very lovely out today all right! I predict a sunset swim...
Author:  Rod True [ Sat Aug 13, 2016 10:39 pm ]
Ya, I've got a/c in my shop Ed :D
Author:  meddlingfool [ Sun Aug 14, 2016 12:02 am ]
But of course you do. One day I hope to as well, but I need to figure out how to make it work with the rh which is more important than my comfort...
Author:  fingerstyle1978 [ Sun Aug 14, 2016 11:43 am ]
I quit working until fall. It's only 85 in my shop but I can't deal with the heat. Anything over 70 and I'm a sweaty mess. A year in Iraq didn't help.
Author:  printer2 [ Sun Aug 14, 2016 1:41 pm ]
The AC will condense the moisture out of the air as long as you do not have a lot of air coming in from outside. I have been running my AC to keep the RH down, got it down to 46% at 70 F. At work we knock the RH down by cooling and then heating up the air. Not particularly energy efficient but when you have a RH that you have to limit things to you don't worry too much about being green. A dehumidifier that people run does the same thing but the warm side of the coil radiates the heat back in the room. Mind you, you do have a good heat generating device as it is.
Author:  meddlingfool [ Sun Aug 14, 2016 8:44 pm ]
Well, I I is they need to have the heat vented outside, which makes me think it would have to draw untreated air in from somewhere outside...
Author:  printer2 [ Mon Aug 15, 2016 6:03 am ]
Always a catch. On a smaller scale I recently directed my vacuum system's exhaust outside in my garage and it is cooler. But I don't build out there.
Author:  Rod True [ Tue Aug 16, 2016 1:51 am ]
One room only. Your bracing room of course. Use a box A/C 6000 BTM should do just fine. I use mine to help control the RH. It keeps my shop at 50% all summer long, but I tend not to build much in the summer months...I know you can't do that though.
Author:  meddlingfool [ Tue Aug 16, 2016 10:27 am ]
But wouldn't new untreated air need to come in to replace the hot air being vented outside, causing RH stability? Not quite sure how he systems actually work...
